mp c6501
  • Daprince
    • Sep 2013
    • 2
    [Error Code] mp c6501
    Hi guys please help me I've got a MP C6501 it gives sc 410-413 and 496
  • turbojetboy
    • Aug 2009
    • 279
    Re: mp c6501
    I would say you are up for a major PM. These codes are all toner density related and usually indicate worn PCU's, Devs and ITB assy. You REALLY need to know what your doing with these otherwise you will end up in an almighty mess.
    • Zaxxon
      • 608
      Re: mp c6501
      Even if you think you know what your doing, you will properly still mess this up
      PM Kit assy from Ricoh:
      D081KFUS
      D081K150
      D081K200
      D081K300
      D081K400
      D081K450
      Please start you post with brand, model, problem.
        • 37357
        Re: mp c6501
        Check the PM counters to see what is past recommended count. Be certain to follow the instructions in the SM exactly, especially if replacing the developer. Clean the image density sensors with alcohol wipes. Also check TSB 017 "LIGHT DENSITY, TONER SCATTERING OR SC4XX."
        • JustManuals
          • Jan 2006
          • 9838
          Re: mp c6501
          Paul@justmanuals.com
