How are you members... I have a little but big problem; after doing a reset on the machine; the touchscreen of the printer is not working; this is pretty serious since I can't do anything without the touchscreen; is there anyway to navigate in SP-MODE and fix this without the use of the touchscreen?
Ricoh Savin sdc326A
Try Clear\modes 1993 clear/stop x5. that is, press clear/stop 5 times. Then when the screen changes, press # for the touch screen adjustment. Follow the instructionssigpic
A+; Network +; PDI+ -
submelo
Thanks but that combination of code does not change anything... maybe it's different for different machines?Comment
sigpicWe can all Win, but at the end we all loose. Save the greyhoundComment
sigpic
A+; Network +; PDI+Comment
