File Format Converter
  • CRISTIAN MULLER
    • Feb 2013
    • 145
    Hello, everybody, my company buy a new MP Cw2200, and came with a file format converter board, I install the board but, I really want know, what is file format converter is desing for?what is the propose? how to use in the best way? thanks for enlighthning.
  • m2digital
    • Dec 2013
    • 19
    Re: File Format Converter
    How I understand it, the file format converter is to convert files stored in the Document Server from a format that a copier understands into a format that a computer understands, in particulary into PDF format or TIFF format, so that the documents scanned into the Document Server can be downloaded and viewed from a computer.
    From a computer start a web browser, type in the IP address of the copier to access Web Image Monitor, then click on Document Server, and if there are scanned files in the Document Server, you can download them in PDF or TIFF format.
    • CRISTIAN MULLER
      • Feb 2013
      • 145
      Thanks for answer me, so is the same thing there I scan to a folder om my PC in PDF or TIFF format?
      • m2digital
        • Dec 2013
        • 19
        How I understand it, you can always scan to a folder in PDF or TIFF and you do not need a file format converter for that.
        File Format Converter is only needed to download files stored in the Document Server, that is on the hard drive of the copier. This is because the documents in the Document Server are stored in a unique format specifically for the copier, these files are bigger in size with a better resolution than storing the same file in PDF or TIFF.
        When you convert a scanned image to PDF or TIFF, you will lose out on the quality of the scanned image.
        • CRISTIAN MULLER
          • Feb 2013
          • 145
          Thanks again and again.
