2nd hand copier setup.. accessing WIM and printing issues
  • Richariri
    • Dec 2013
    • 163
    Good afternoon y'all
    We have just received a 2nd hand MP C5000 and I have been going through the basic tests before doing a refurb.
    This MFP has come from Twente (large dutch IT company) and has been setup with an 'Access Control Range' 010.015.150.001 - 010.015.150.254
    So my issue is this:
    I did a print test and it fails every time on our basic office star network. I can ping the device and I can scan to folder with the device. The driver is also flagging up low toner, so there's definitely some communication going on. I can't login to web image monitor either, I keep getting '403 forbidden' when i type in the IP address of the MFP.
    Can I disable access rights from the copier itself?
    so far I have tried setting my laptop up with IP '010.015.150.002' and subnet '255.255.255.0' (is the subnet correct? there are 4 different Access Control Ranges [networks] setup on this machine. so maybe it should be 255.0.0.0) and attempting to access WIM, but i got the same fault.
    I believe this is what's stopping me from printing... I can't seem to make heads or tails of it
  • skynetto
    • Sep 2012
    • 257
    Re: 2nd hand copier setup.. accessing WIM and printing issues
    Connect to the machine via telnet and execute this command:
    ACCESS FLUSH
    exit and than you can connect via WIM.
    • Richariri
      • Dec 2013
      • 163
      ACCESS FLUSH
      Sorry, I only have little experience working with networks I'm a sevice repair guy mainly...
      could you explain how I connect via telnet?
      I can bring up the telnet client in XP, but how do I use it as you've described?
      • skynetto
        • Sep 2012
        • 257
        You should have telnet installed on your PC. It is installed by default on XP and you have to install it in Windows Vista/7/8 using this simple guide:
        Windows 7 does not have Telnet enabled by default. Follow these steps to re-enable it.
        Once you've installed it open a command prompt and execute: telnet
        it ask you for a command and just give it this command:
        Code:
        o IP_OF_THE_MACHINE (the ip should be in your subnet range, let's say 192.168.1.145/255.255.255.0)
        bare in mind there's an o (letter o not zero) before IP wich stands for open
        that it'll ask you for credentials (as always: admin/blank_password)
        Once you've gained access just execute the command above
        Code:
        access flush
        and than you're good to go.
        p.s.: I think even your boss don't know how to do it
        • Richariri
          • Dec 2013
          • 163
          Code:
          Code:
          access flush
          I did all as described, after entering 'access flush' and hitting enter it did not say anything regarding the status so I assumed it was complete.
          I've rebooted the machine, but access rights are still setup.
          • Bantams
            • Jun 2012
            • 603
            he could do that or he could do it the easy way and reset the user tools system setting to default by pressing the *key and the system key on the copiers user tools display at the same time :/
            • Richariri
              • Dec 2013
              • 163
              OK, I had to logout of telnet to save the changes i'd made... access rights have now been cleared.
              I would like to reset system settings as described... do I hold the ./* key then press system settings? (have tried pressing at same time with no result)
              can't quite follow your instructions. (is it an sp mode in special?)
              • skynetto
                • Sep 2012
                • 257
                Well never stop learning
                • Richariri
                  • Dec 2013
                  • 163
                  secondly there are several options which say I 'do not have the privileges to use this function'
                  the login option has disappeared from user tools, so I can't login as admin to change this
                  • HDSB
                    Field Tech
                    • Feb 2013
                    • 64
                    hold the # key and press system settings, gives you option to reset to factory. also works with copier, printer, fax, scanner. good practice if you're refurbing the device.
                    • Bantams
                      • Jun 2012
                      • 603
                      damn I always get the # and * keys mixed up must be my age and the fact I spent 2 hours on a venus today only to have to spend 4 hours fixing the mofo tomorrow
                      This Job is awesome BTW don't let anyone put you off
                      • collme
                        Ricoh tech
                        • 221
                        your fave machine that Venus lol
                        • Bantams
                          • Jun 2012
                          • 603
                          that and my Van that lets me get home in 1 hour everyday regardless of a little bit of snowfall :P
                          • collme
                            Ricoh tech
                            • 221
                            snow did not stop me, was the idiots who clogged the roads up between me and home
