SC901 on Ricoh2045
  • greyfox
    • May 2010
    • 20
    [Error Code] SC901 on Ricoh2045
    Hello Guys,
    Good Day!
    I would like to ask to my fellow tech on how can i solve the SC901 on Ricoh 2045?, upon checking on the SP 5915
    mechanical counter detection i notice that the counter is not detected (0:not detected)
    so what i did i took out the mechanical counter and test to the other machine and it works fine.
    also checked the connection from the board and its all good.
    I really appreciate your help, Thanks in advance
  • sandmanmac
    • 3981
    I'd go with IOB next
    • greyfox
      • May 2010
      • 20
      Re: SC901 on Ricoh2045
      is SC901 also refers to IOB? if the mechanical counters is ok?
      thanks
      • sandmanmac
        • 3981
        thanks
        IOB is where the voltage for the counter comes from
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          You can ohm the counter coil and measure voltage to the coil, the pulse will only blip a DVM though. The other 2 contacts only confiirm the counter is connected to the board, but can be checked with a meter. Ricoh mechanical counter 101.
          Mystic Crystal Revelations
          • sandmanmac
            • 3981
            Holy cow TB! My head now looks like your avatar!
            Are you sure that's only level 101?
            I'm very weak on the electrical side.
            So if there's no 'blips'. IOB?
            • Tonerbomb
              • Feb 2005
              • 2589
              You better have a very good DVM to see the pulse blip the meter..............................The electronic counter is still in NVram...
              This didn't really change much from analog to early digital's. The c series started to eliminate hard counters and the 01's and 02's really changed it........try to hook to a coin op..................
