Ricoh MP 2550 Jamming when duplexing Error Code J026 Single Side Works great
  • sagar4
    • Dec 2012
    • 127
    [Error Code] Ricoh MP 2550 Jamming when duplexing Error Code J026 Single Side Works great
    I have a Ricoh MP 2550 that only jams when doing two sided copying. Single sided works just find. Tried with bridge and finisher disconnected still same problem. The first side comes all the way out instead of going back in to do the second side and then I get an J026 error code. Any help would be greatly appreciated. Thanks in advance. And yes I have the service manual.
    "Broken again"
  • Zaxxon
    • 608
    Re: Ricoh MP 2550 Jamming when duplexing Error Code J026 Single Side Works great
    Haven't got any of these my self, but found this on tier2.
    [Symptom]
    Wrinkling occurs on the paper sometimes only when using the duplex unit.
    [Cause]
    The front hook of the fusing entrance guide plate is bent.
    [Resolution]
    Replace the fusing entrance guide.
    [Symptom]
    Skew + jams from Duplex and Bypass.
    [Cause]
    Duplex Guide Plate deformed and Duplex/Bypass Motor defect.
    [Action]
    Replace Duplex Guide Plate (Section 4 item 14).
    Replace Duplex/Bypass Motor (Section 6 item 9)
    Please start you post with brand, model, problem.
    • TonerMunkeh
      Professional Moron
      • 3865
      Add to that the actuator on the duplex junction gate being broken off.
      Hit it.
      • sagar4
        • Dec 2012
        • 127
        Okay I will check the gate. The paper comes out with no creases, bends, it just comes out nice and straight. Thanks
        "Broken again"
        • Counsel
          • Aug 2011
          • 530
          If the paper comes out but doesnt go back to duplex my guess is a sensor is not triggered either a flag is broken or its dirty, it should trigger a sensor so the machine knows when to reverse feed might pull the covers off and watch a page try to duplex make sure everything actuates, i cant picture that model in my head but either a sensor isnt triggered or the actuator for the gate is not working.
          • Debs1964
            • Oct 2010
            • 1690
            Lower Gate Pawl (D3694664) broken, the actuator that moves it into position for going into the duplex paper path breaks off, so it stays, constantly, in the simplex position
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • collme
              Ricoh tech
              • 221
              lower gate pawl part no D3694664
              • Debs1964
                • Oct 2010
                • 1690
                Beat you to it
                • collme
                  Ricoh tech
                  • 221
                  Originally posted by Debs1964
                  Beat you to it
                  lol
                  • Debs1964
                    • Oct 2010
                    • 1690
                    It's such a common problem, I had to replace one today
                    • topman
                      • May 2012
                      • 2
                      Same problem with Ricoh MP 3350...Did you find any solution?
                        • 37357
                        This thread is nearly five years dead and buried.
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          Open a new thread and include EVERYTHING you have tried to date..!!!!
                          • davel
                            • Oct 2011
                            • 1095
                            Different model, same answers.
