Ricoh2022 weird image
  • greyfox
    • May 2010
    • 20
    [Misc] Ricoh2022 weird image
    Hello Guys,
    Really appreciate if someone can share their thoughts on how to remove the weird image appearing on the copy counter, Please see attached file:
    20140130151409721.pdf
    Status:
    Newly Replaced PCU type 1027
    cleaned LD unit
    cleaned Memory
    Thanks in advance
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh2022 weird image
    Fold the printout so that two of the repeating patterns overlap, then check the resulting size to see what roller it matches up with in the machine. Most likely there is a fault on the LFR.
    • greyfox
      • May 2010
      • 20
      I tried to jam the paper from the PCU i saw this image on the drum.
      • m2digital
        • Dec 2013
        • 19
        Contaminated Hot Roller in the Fuser Unit?
        Did this ghost image appear after you replaced PCU or was it the same with the old PCU?
        • CrapAimer
          • 296
          Have you replace the upper fuser roller. looks like ghosting
          • collme
            Ricoh tech
            • 221
            normally if it is fuser then it would be repeating image of the page which this is not doing, also image is on the drum, are you sure when you were fitting the new drum some sticky tape did not stick to the drum from the packaging and pulled back off leaving a sticky residue behind
            • sandmanmac
              • 3981
              Definitely a defective PCU issue. and if the sample is an indication of the verall print quality from the machine, then the "weird image" you're getting, Then that PCU has bigger issues
              • Herrmann
                • Jan 2006
                • 792
                If you divide the distance between two marks through pi, you will get the diameter of the potentially faulty element. I zoomed the picture to A4 size and got a diameter of nearly 3cm, so it is the drum. BTW, the image is really washed out too, so maybe it is time for a new pcu.
                If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                • Counsel
                  • Aug 2011
                  • 529
                  If its that washed out when you printed it then either the pcu wasnt initialized or your pcu is junk the fact that you have this spot on the drum when you pulled the door would tell me your pcu was crap to begin with. I would try another pcu and check your transfer rollers last replacement as well. Also make sure to initialize that pcu when you install it.
                  • jtd55
                    • Dec 2013
                    • 30
                    defo looks like pcu or fuser is the machine in a place were temps differ big style (Damp/Hot) ?
                    • Butrus
                      • Jan 2012
                      • 115
                      These circles seem all different to me...
                      Is this print or copy?
                      Did you check/clean the glass?
                      • collme
                        Ricoh tech
                        • 221
                        The circles are w
                        here he has circled the faint copy issue and is not what the machine is printing lol
                        • Butrus
                          • Jan 2012
                          • 115
                          lol indeed.
                          On my old monitor its hardly seen whats inside circles....printed it out and see now...
                          • gear13z
                            • Sep 2011
                            • 68
                            your problem is in the drum, take a flashlight and see that character in the drum, I think is is been scratch or something, when you open the machine for the first time and print the counter, you will not find those image but as you go along...after several copies, drum heated, the image become darker...right? I encounter this problem 2 years ago. better replace the drum.
                            .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
                              • 37488
                              If you don't what to replace the entire PCU, the drum for the B039 seures will fit.
