MP6001
  • tibbs
    • Aug 2008
    • 223
    MP6001
    Broken Tray 1, spanner symbol appearing, not allowing users to close or operate the tray.Any hints why this is so.
  • imaginemoko
    unTrusted Tech
    • Jan 2008
    • 289
    Re: MP6001
    check if there is any paper obstruction in the drive of tandem tray 1...
    fix the customer first then fix the machine... its simple and makes life more easy.
    • 41-willys
      • May 2010
      • 36
      Re: MP6001
      check the side gates and the left fence are not broke or hanging up
      • JustManuals
        • Jan 2006
        • 9838
        Re: MP6001
        Paul@justmanuals.com
          • 36745
          Re: MP6001
          Remove the right (lift) tray and inspect.
          1. Remove all paper.
          2. Remove the tray front (2 screws)
          3. Remove the two screws holding the left tray to the left most rail to allow the left tray to pull out a couple of inches more.
          4. Remove the two screws holding the right tray to the rail.
          5. Slide the rail only back into the machine
          6. Slightly lift the right tray and remove it.
          • lolways
            • 5
            Re: MP6001
            If there is paper behind the tray jamming the mech, this could be a symptom for bald tyres.
            • Zaxxon
              • 608
              Re: MP6001
              It could be that the drawer has been opened, when copier is pushing the paper stack to the right.
              After this the guide pushing the stack, is stuck in the middle position, the customer is then putting paper in the left drawer, causing major crash, and broken lifting wires and bend side plates. Just had one
              Please start you post with brand, model, problem.
              • watson
                • Sep 2009
                • 64
                Re: MP6001
                Make sure the lever in the lower left corner in the back of tray one isn't deformed. That can prevent the tray from going all the way in.
