Ricoh MPC scan question????
  • techspec
    • Dec 2008
    • 128
    I've had a query regarding the manual input button on the touch panel for inputting addresses. Can it be disabled?
  • sandmanmac
    • 3996
    Re: Ricoh MPC scan question????
    No (as far as I know), and why would that be an issue?
    • teebee1234
      • Jul 2008
      • 1670
      Actually, I believe you can. Look for Extended Security settings in user tools. There you should be able to disable manual input along with a few other choices.
      *there are companies that don't want information to go outside the confines of the specified address book.
      • techspec
        • Dec 2008
        • 128
        Your spot on with your last paragraph.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2586
          I have a customer that does something like this, but they limit the sending email account so it can't send outside of their .biz domain.
          Mystic Crystal Revelations
          • techspec
            • Dec 2008
            • 128
            That is the option they can follow tonerbomb but you know what customers are like!
            • teebee1234
              • Jul 2008
              • 1670
              Procedure for Changing the Extended Security Functions
              This section describes how to Change the Extended Security Functions.
              1. Press the [User Tools/Counter] key.
              2. Press [System Settings].
              3. Press [Administrator Tools].
              4. Press [Extended Security].
              6. Specifying the Extended Security Functions
              5. Press the setting you want to change, and change the setting.
              6. Press [OK].
              7. Press the [User Tools/Counter] key.
              Restrict Use of DestinationsOff
              Restrict Adding of User DestinationsOff
              Restrict Display of User InformationOff
