ricoh mp 161
  • kopirmaster
    • Apr 2011
    • 70
    ricoh mp 161
    default password and user has been change ,and web image disabled.Now i cant change the ip adres even with supervisor .How i can enable web image ?
  • Eric1968
    • 2458
    Re: ricoh mp 161
    You can't change the IP-adress with the supervisor account. This account can only reset the admin account. If you can't log in using the supervisor account, the only thing left to do is change the NVRAM.
    • ricmartinho
      • 142
      Re: ricoh mp 161
      Like Eric1968 said, login with supervisor, reset the admin password and turn Administrator authentication off. If you can't acess through Web Image Monitor, print the Network Settings and check if Acess Control is enabled.
      • JustManuals
        • Jan 2006
        • 9838
        Re: ricoh mp 161
        Paul@justmanuals.com
        • kopirmaster
          • Apr 2011
          • 70
          Re: ricoh mp 161
          Yes i know ,but the supervisior acount has been change .Where i can find disable/enable web image monitor ?
          • ricmartinho
            • 142
            Re: ricoh mp 161
            I think the only solution is to replace the nvram.
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              Re: ricoh mp 161
              You could try downloading the NVRAM and editing it in a simple hex editor, then reupload to the machine. http://www.copytechnet.com/forums/sh...tml#post272337
              Otherwise it is a new NVRAM you require.
