mpc3003 fuser sc
  • slot
    • Jul 2008
    • 341
    mpc3003 fuser sc
    we have a mpc3003 that had a paper jam in the fuse that caused sc544> On the mpc4502 etc you can reset this by a simple fuse
    is this the same for the 3 type machine as we don't want to order a new fuser for no reason the copier is only a month old. If there is a fues what is the number cant seeit in the parts manual or on my ricoh
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: mpc3003 fuser sc
    http://www.copytechnet.com/forums/sh...-in-fuser-unit
    I also use the fuse from the 02 fuser sleeve units and SPC811 fusers.
    • slot
      • Jul 2008
      • 341
      got the code reset with the M026 type fuse but the connector is a different size. Had to make a cable up got caught out as the code wont reset( sc554 02) as the firmware has to be at least J on engine if its not the screen will lock up when you run SP810 02
      • Bantams
        • Jun 2012
        • 603
        5-810-1 resets those jams in fuser codes or it does on the one we have that jams in the fuser now and again.
        • Tjompa
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Check my post above for the fuse part number.
              • 37489
              On most machines that require a fuse to reset a service code or a supply counter, the fuse is usually a sub-amp fuse, ie less than 1 amp. If you can find the amperage rating and type of the fuse, I am sure you can find them on the internet somewhere. You will then have to come up with a way to connect them. Since Ricoh does include a fuse with the sleeve unit, which you usually don't need when doing a PM on the fusing unit, it is easier to just use it.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                FYI:The fuse "sometimes"comes with the fusing sleeve.
                We've had a few lately where we've begun a refurb and opened the new sleeve unit box only to find no fuse.
                Rang support and were told that it's "a lucky dip at the moment"...sometimes you get a fuse and sometimes not...helpful much?
