Lanier 328c Black Drum Install
  • doug
    • Dec 2011
    • 198
    Hi guys,
    When replacing black drum on a lanier 328c color copier, do i have to reset or initialize the drum through the soft switches?
    Doug
  • sandmanmac
    • 3981
    Re: Lanier 328c Black Drum Install
    Originally posted by doug
    Hi guys,
    Doug
    Do SP5-999-001 (new unit set).
    Power off machine. Install new PCU. Power on, and PCU initialization is done
    • doug
      • Dec 2011
      • 198
      Thank you! I greatly appreciate that information.
      Doug
      • Drummer
        • Feb 2013
        • 46
        Make sure you push the "ok" for the particular unit, I made the mistake before when replacing multiple units at once of going into the sp and executing but not touching ok after each one. Only the ones that "ok" was pressed on initialize.
        • doug
          • Dec 2011
          • 198
          Thank you for this information, this would be something i would do in a hurry!
          Doug
