Hi everyone.
I'm working on an Aficio MP 6002 with an SC550 error code, which I know to be a fusing web end condition. I've got two problems with this particular error.
Problem #1 is that there is still plenty of fusing web left - it looks like it is about 1/5 used with the majority of the roll unused. I cleaned the web end sensor and checked all the connectors on the web unit. I haven't replaced the web end sensor or anything else yet. My next line of reasoning was to go into the service mode and check the value of SP1902-001 and see if resetting the code would result in the code actually resetting or if it would come back. Which leads me to...
Problem #2 I can't enter the service mode. I'm using the time honored "reset" 107 "stop" (hold for 5 seconds). But to no avail. This is the only MP 6002 that I have out in the field (I work for a small independent shop) and I noticed that the control panel is slightly changed from the older Aficio 2060 etc. I've tried various combinations of "energy saver/reset/clear", 107, "clear/stop/reset" with no luck. Has the procedure to enter service mode changed? I'm a bit stumped here.
Thanks in advance for any help that you can provide - either in ideas on the false SC550 or on any potential problems getting into the service mode.
