Ricoh Aficio MP 2000 printing landscape then portrait.
  • sonicpc
    #16
    Re: Ricoh Aficio MP 2000 printing landscape then portrait.
    Originally posted by MPSJIMBO
    Hello Fellow Techs,
    I have a Ricoh Aficio MP2000 Copier. Every time I print a multi-page document It prints a landscape print out then a portrait print out. now the printouts are not duplicate it just alternates the paper. I tried reloading the driver, and tried different pc's still the same issue. The driver was retrieved from the OEM website (just an FYI) any help would be greatly appreciated. Thanks
    select printer as ricoh***
    in print preferences settings please select paper trayas bypass tray .
    then select paper size as A4 or your
    paper size
    open the bypass tray and insert paper
    then print
      have you checked the PAGE properties in the FILE? could have that definition in the file properties
      • StephenB
        • Aug 2015
        • 238
        #18
        I've had this happen, It was a driver issue. If you are using the PCL 6 try the PCL 5, or vise versa
        • davel
          • Oct 2011
          • 1079
          #19
          Sonicpc
          This thread is 5 years old, your pic is not MP 2000, driver is Konica, and why would you use bypass.
