Ricoh 3352 Ejecting 2nd sheet of paper
  • rtiql8n
    • Jul 2012
    • 14
    [Jamming] Ricoh 3352 Ejecting 2nd sheet of paper
    My customer has a Ricoh 3352 bought new from us but now has 220k on it. The first paper tray will make a copy fine but the second copy jams every time. After making a single copy you see that a second sheet of paper has already started its way towards the vertical transport rollers. (like the pickup rollers grabbed two sheets but stopped one a little late). So when another copy or print job is sent, the tray starts to send that sheet of paper as it normally would only the sheet is already at the vertical transport rollers. The VT rollers are not ready for the paper so they don't turn yet. Pickup rollers are trying to send paper to the VT rollers but since the sheet is already there it jams. We have replaced all clutches in that tray and rollers. All sensors are operating normally. The SMC report doesn't look out of the ordinary but should I adjust clutch timing on the separation roller? If so, why would it do this all of a sudden? If not, what should I look at? Thanks for your help.
    Kirt
    • 37452
    Re: Ricoh 3352 Ejecting 2nd sheet of paper
    Have you tryed cleaning the separation roller? You might also have a weak torque limitter.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      I would KISS IT, Keep It Simple S...............................
      Like slimslob said clean or replace rollers/sep pads....
      Mystic Crystal Revelations
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • rickybobby606
          You need to replace the double feed prevention roller and the one way needle bearing holder.. or ckuff the shaft where it rides.. also the primary pickup paper feed roller could cause this or even all the above at once..also if there is high humidity their paper may just need to be fanned to get rid of static build up!!! Goodluck!!!
          • rickybobby606
            It is possible but unlikely, unless it is doing that continually.. It is possible it is your paper feed clutch..
            Here is an idea, swap the top and bottom paper feed clutches around and see if there is a different effect. Goodlick
            • rickybobby606
              Have them try a better brand of paper!!!
              • Counsel
                • Aug 2011
                • 529
                I would test again using a different tray as your source if the other trays work fine and its limited to just this tray then replace the feed rollers and seperation for that tray.
                • rtiql8n
                  • Jul 2012
                  • 14
                  I forgot to mention that we replaced the torque limiter(s). We even replaced all rollers. Not just the separation roller. Any new thoughts?
                  • rthonpm
                    • Aug 2007
                    • 2853
                    Check the paper end sensor. I had a flaky one on a C4500 that would do something very similar.
                    • rtiql8n
                      • Jul 2012
                      • 14
                      Thanks rthonpm
                      If it were a paper end sensor, would that create the fact that it pulled the second sheet out about 2 inches? Seems to me that its still a mechanical issue. But I will swap sensors between the trays anyway and give that a try. Also, thanks Counsel for your suggestion. The tray swap is something I have not tried yet. These are all great ideas. I'll let you know what I find out.
                      • 41-willys
                        • May 2010
                        • 36
                        is the machine reading the correct paper size and direction? had a simular problem when I was rushing because I was backed up on calls
                          • 37452
                          This a definite posibility. If the clutch is sticking intermittantly, it could actually continue to feed the next sheet of paper.
                          • Gary Bowen
                            Bowdog
                            • Mar 2008
                            • 250
                            Was this problem ever resolved? I have currently the same problem with a MP 3352 with 104K on it. I thought it was the Paper Feed Clutch sticking and feeding a second sheet of paper. I replaced the clutch BUT this did not fix the problem. What I found was the Paper Feed Clutch shut OFF momentarily after it picks up the sheet of paper but turns back ON for about 1 1/2 seconds and feeds a second sheet into the VT Rollers. Tray 2 does the same thing but the Tray 2 Feed Clutch only comes ON for about a 1/4 second after it initially shuts OFF; this is not enough to send the sheet of paper into the 2nd VT Rollers. This has nothing to do with Sensors or paper orientation. I have the latest firmware installed, reseated BCU Board connectors and did an ALL MEMORY CLEAR but the problem is still there. I suspect the BCU Board but am bothered by the fact that I see the Tray 2 Paper Feed Clutch doing the same thing.
                            • Gary Bowen
                              Bowdog
                              • Mar 2008
                              • 250
                              I will update the last post myself. The beauty of being able to spend some time diagnosing a problem. Ricoh Tech Support suggested I replace the BCU Board (always the expensive fix and no quarantee). Turns out it was the Paper Feed Sensor (AW010128); it was not changing state. I duplicated the problem with Tray 2 by putting electrical tape over the Paper Feed Sensor and the same problem occured from Tray 2; the Paper Feed Clutch would come ON for an additional 1-1/2 seconds.The PB3050 (Dual Tray 3 for the MP C2800/C3300) uses the same sensor so used it to confirm the fix. On another forum, a tech with the same problem said there was a lot of toner dumped down inside the machine from a severe toner spill and this caused the sensor to fail, but this MFP was almost spotless. The Paper Feed Sensor only changes state once (to 0) after paper is fed and stays in that state until the tray runs out of paper or the tray is opnened and closed (goes back to a 1); powering OFF and ON the copier will not change the status of this sensor.
