mpc 7501 sc569
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    [Error Code] mpc 7501 sc569
    Hi all.
    I have an mpc 7501 that gives sc569. What happens is when thw mc is switched on the fuser release motor drives then stops which is fine. Then a few moments later it continued to drive follwed by a clunking noise then sc 569. I have replaced home position sensor and releae motor but still the same issue. The workaround for now is to let the motor drive to pressue on and disconnect the motor. And also disable sc for fuser release sp1159.
    Next step vbcu??
    Any suggestions?
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • Jomama46
    • 2900
    Re: mpc 7501 sc569
    Replace the gears in the fuser release section
    sigpic
    A+; Network +; PDI+
    • JustManuals
      • Jan 2006
      • 9838
      Re: mpc 7501 sc569
      http://www.justmanuals.com
      Paul@justmanuals.com
      • turbojetboy
        • Aug 2009
        • 279
        Re: mpc 7501 sc569
        I have replaced MANY times the small metal gears, the small steel shaft and most importantly the bracket that contains a pressed in bush (which actually is the weakness area in this mechanism). The bush wears / comes loose and then the gears run on bad alignment and start badly wearing and chipping teeth etc. All of this is right behind the motor assy.
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          I did look at the gears. I qill have a closer look next time I visit. I manually rotated them and they seemed ok. Thanks for the tips
          • leo34staffs
            copierman
            • Aug 2007
            • 503
            Re: mpc 7501 sc569
            Do you have part numbers for these parts? shaft and bracket, gears as looking at the 3d manual its a bit tricky as to which parts to order, im not lazy...just not sure.
            • Jomama46
              • 2900
              Re: mpc 7501 sc569
              This is from the C7500 parts list, I'm not sure if its the same numbers for the c7501. Maybe someone else can confirm. Or see if the numbers are listed in the List you have.
              BTW I HATE those 3D catalogs
              sigpic
              A+; Network +; PDI+
