Fax board problem
  • CRISTIAN MULLER
    • Feb 2013
    • 145
    Fax board problem
    hello guys, i have a MP 2550 without fax board, and i a mp 2851 with one that i dont need, i'm trying to move the board from 2851 to 2550, but machine dont recognize the new board, i already have check and board is compatible.i already change another board with a mp3350, i'm trying to see at manual about some option in service mode to enable or disable this feature, but if one of you guys know how, please help me. very thanks.
  • sandmanmac
    • 3981
    Re: Fax board problem
    If it is a known working fax unit, then I would check the MBU Connection to the FCU. It can come loose quite easily, and the fax option won't be recognized. I had this happen just recently when I was swapping a fax unit on a machine.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Originally posted by sandmanmac
      If it is a known working fax unit, then I would check the MBU Connection to the FCU. It can come loose quite easily, and the fax option won't be recognized. I had this happen just recently when I was swapping a fax unit on the same machine.
      X2 !!
      Mystic Crystal Revelations
        • 37490
        FAX option for the MP 2550B and the MP 2851 are not the same. MP 2550B requires a Type 3350 D361. MP2851 uses a Type 3351 D510. The part number on the FCU might be the same, but the firmware loaded on the MBU is not.
        • CRISTIAN MULLER
          • Feb 2013
          • 145
          you're right, no matter what i did, just cant make board to be recognized, thank for the help, i will change the client machine.
