Ricoh Mp 2510 SD Card Reply Urgent
  • faraz_afaq
    • Apr 2013
    • 27
    Hy guys,
    I have a one question to all friends. Kindly let me know that can we copy Printer/Scanner Kit or we make new printer/scanner kit via using blank SD Card. I have also firmware of this machine.
    M.Faraz
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh Mp 2510 SD Card Reply Urgent
    No, you can't. You can only fit a new one. The part number is D310 5017.
    Hit it.
    • logrady2331
      • Feb 2011
      • 301
      Go to www.recycledparts.us and you can get the SD card there for at least half price.
      • tcs04
        FORMER Techie
        • 1183
        MPC 7501, the final frontier...... ? Discuss
        QUOTE=TonerMunkeh;404847]No, you can't. You can only fit a new one. The part number is D310 5017.[/QUOTE]
        • TonerMunkeh
          Professional Moron
          • 3865
          Hah, Satan's MFP. Burn them all.
          Hit it.
            • 37560
            [/QUOTE]
            Most of the used parts sites such as www.recycledparts.us will pull the entire Printer/Scanner kit if they have a machine that has the kit and not the imbedded version. The main thing with adding only the SD card is that a basic machine needs more than the SD card to install Printer/Scanner. Give them the part number all they will get you everything that you need at, as tonermunkeh said at about half the price or less.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              Most of the used parts sites such as www.recycledparts.us will pull the entire Printer/Scanner kit if they have a machine that has the kit and not the imbedded version. The main thing with adding only the SD card is that a basic machine needs more than the SD card to install Printer/Scanner. Give them the part number all they will get you everything that you need at, as tonermunkeh said at about half the price or less.[/QUOTE]
              The recycled guy's are a good source for this, But in the past I have ordered the P/S card as a part from Ricoh with the print scan buttons, and sourced the additionally needed memory from the after market and converted a machine to the print scan version for under $200. That is when the model has the on board NIC...................
              Mystic Crystal Revelations
              • faraz_afaq
                • Apr 2013
                • 27
                Ok but tell me the reason why we purchase new one. I think that we have many ways to copy that card guys you have any reason why we cannot copy this card and i am already copy sd card in blank sd card but now luck. machine did'nt show the printer option. what is the logic can any one tell me may be we will resolve this issue and save our money.
                thanks
                M.Faraz
                  • 37560
                  I believe that Ricoh places a low level marker file on their SD cards that identifies the card to the machine as an options firmware card. Without this, the machine will not accept the firmware. This is for Copywrite protection. If you move an option from one card to another, you have to store the SD as proof that you have purchased the option. If at sometime in the future you want to remove the option, you have to move the firmware back to the original SD card. If you format or write to the SD card in any way on a computer, the MFP will no longer recognize it as a firmware card. The only exception is the JAVA VM card. You are allowed to upgrade the VM firmware on a PC using Ricoh's update utility. If you try to just copy the update to the VM card without using the update utility, the card becomes useless.
                  • faraz_afaq
                    • Apr 2013
                    • 27
                    Thanks For giving me Instruction regarding this subject.
                    Thanks to all.
                    • Polarbear
                      • Feb 2012
                      • 1070
                      +1 on the low level marker theory.
                      I think they write these cards with operating system other than Windows, like Linux or such. I did some homework on SD card security and Windows, and Windows will write things to any SD card, that the Ricoh machines will not like.
                      Press the GREEN button!!
                      • rthonpm
                        • Aug 2007
                        • 2859
                        The copier OS is NetBSD when you break it all down so it would be something that a Unix OS could read that Windows doesn't see. I'd venture to guess that there's a part of the boot manager for the machine that writes a key string to the card that signs it for that particular device.
                        Think of it like encrypting an SD card on your phone: if you put that card into another phone of the same model, it won't be able to decrypt it since the new phone is using a different key hash.
