I went behind a tech was having problems with a SR-880 that is attached to a Aficio 3045. He was experiencing problems with intermittent SC-724 error codes, false finisher jams, and the staples were stapling off the page. He replaced the staple cartridge and finally the stapler assembly, but the problem returned.
When I arrived the machine was displaying false jams and SC 724's. I pulled the staple cartridge and readjusted the staples. I reset connectors on the logic board and made sure the jogger fences were moving correctly. This corrected the errors that I was getting, however the staples were not stapling correctly. I tried making adjustments to the stapling position in service mode but it had no effect. I suspect the logic board since there aren't very many sensors or adjustments that can be done.
Has anyone experienced this problem on the SR-880"s?
