2075 no scan to file in win 8 64bit
  • a-copy
    • 8
    [Misc] 2075 no scan to file in win 8 64bit
    Hello everybody,
    I have the following problem,
    in a ricoh 2075 i cant scan a file in a folder on win 8 64bit,
    While win7 32bit it's ok.
  • sandmanmac
    • 3964
    Re: 2075 no scan to file in win 8 64bit
    Originally posted by a-copy
    Hello everybody,
    There are 3 main reasons for this: Firmware, firmware, and firmware.
    (although I'm unsure if it's even available for that older unit)
    There are dozens of threads relating to scanning to Win 8.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      sandmanmac got it RIGHT!!! FRIMWAR, FRIMWAR, FRIMWAR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      Mystic Crystal Revelations
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3945
        Frimwar it is!!!
        • rthonpm
          • Aug 2007
          • 2847
          One... Two... Three... Four... I declare a frimwar...
          • Dreama
            • Jan 2013
            • 42
            Definitely Firmware - BUT - is firmware available for this model which fixes this issue ? AF2075's are pretty * old
              • 36807
              Based on the release date I would say that you need Special\Custom B140 NetworkSupport V4.18.2C firmware released 7/1/13.
