"Call Service - PM Call" - How do I turn this off??
  • Helios
    [Misc] "Call Service - PM Call" - How do I turn this off??
    I have this pesky MP 5000SP that keeps crying for a PM call. I have done a PM on this machine not that long ago, and I am not sure on how to clear this message. Does anyone know how?
  • sandmanmac
    • 3985
    Re: "Call Service - PM Call" - How do I turn this off??
    Pesky? What machine doesn't have electronic counters for PM items that need resetting?
    If you've "done a PM", that means you must have a manual right? Otherwise, how would you have performed the necessary SP's for drum, dev, etc.
    The PM Reset SP hasn't changed since the turn of the millenium, and it's the same on every model (only some models have a few more PM items to choose from in the menu).
    • Helios
      Thanks for the non-insightful post. Remember me to pass on the same courtesy the next time we meet. I managed to figure it out anyways, without the use of a manual.
      • shawncrowther
        • Sep 2013
        • 19
        You have 5 posts and been here for 5 minutes
        The post above you was actually used for a reason, if you dont have the manuals why are fixing machines?
        Sounds like an end user trying to save money, I feel sorry for you if this is how you treat people.
        My rule is, no manual NO HELP *exceptions do happen to certain circumstances
        Run along now.
          • 37560
          If you get a Replace Cleaning Web message, there are at least two counters that have to be reset at the same time and then cycle power. There is at least one other thread that covers this and has the SP codes to use.
          • Helios
            The service manuals and parts manuals are poorly translated Japanese - most of the time. Any tech on the field will tell you that the manuals only have 10% of the information that you are looking for, the rest is learned the hard way in the field. Perhaps both of you are lacking the wisdom of knowing "There is no such thing as a stupid question". Both of you treated it like it was.
            I know of the 780x codes to clear various PM parts along with 1902 for the web. Was what not described in the manual was the clearing of the page counter. Thanks anyways.
            • JustManuals
              • Jan 2006
              • 9838
              I don't know what manuals you're looking at but the manuals I sell are all in clear concise English. If a manual doesn't meet my standards, I don't put it out for sale.
              Oh, and you can take that arrogant attitude you have and leave, don't let the door hit you on your way out!
              Paul@justmanuals.com
              • shawncrowther
                • Sep 2013
                • 19
                Amen to this!
                • shawncrowther
                  • Sep 2013
                  • 19
                  Also all the genuine manuals from Ricoh i get are in easy to read format
                  I suggest you either get someone authorized to do the work in future
                  Also I have been in this game for 9 years mate, more than happy to help people who don't treat those with knowledge like s**t!
                  Sure there's no such thing as a stupid question, there is however such thing as a stupid response, and in your case time and time again
                  Shawn
                    • 37560
                    First let's get back to the basics. What is the current total count on the machine? Did you do a 160K PM or a 320K PM? At what total count did you do the PM? If you have a manual, the SPs for clearing PM counters begins on page 605 of the current version of the Service Manual. SP codes for clearing the web 527counters is on page 231. SP for setting the PM Alarm interval and also disabling the PM Alarm is on page 527. I you do not have a manual, order one from Paul. From what I have seen searching for other manuals in the past, you are not going find a better price.
                    • Herostrat
                      • Oct 2012
                      • 220
                      There are actualy some posts about that around here,it's amasing how much can one learn in this place...there are even some posts with links to service manual downloads.
                      That's the purpose of this place after all,we share our experience and help each other,some tech's in here are certified some are independent,fact remains that there is loads of those machines out there and 2 few of us,don't just ask for solution but sometimes share what u allready know.
                      I meet all kinds of tech's every day,I'we seen certified Ricoh tech entering "flat line mode" over some ridiculos problem such as duplex jams...he is 2 dependant on bulitens and service manuals and culdn't see stupid spring missing on pressure rollers.
                      I allso saw independent tech making such mess like burning boards on machine...he mounted similar but wrong board...doesn't take a service manual or part catalog to compare 2 boards.
                      Turn on your logic boards and common sence,put your thinking cap and you'll be fine,service manual is a fine guideline but it's not alpha and omega.
                      Ok I admit i got SP7804 from service manual,yet my point is there's no need to diss Helios if he is new to all this,on the other hand he needs to learn how to "use this place better"
