Gestentner dsm 620
  • jake24482
    • Apr 2011
    • 116
    Gestentner dsm 620
    Hi
    I am working on dsm 620 its popping sc544 I reset it and it ran about a week and the code came back .Can some one tell me what part causing this code .Please let me know if some has any information .
    thanks in advance
  • 41-willys
    • May 2010
    • 36
    Re: Gestentner dsm 620
    replace the thermistors and go from there.
    • jake24482
      • Apr 2011
      • 116
      both of them
        • 37529
        Doesn't hurt to replace both. The code is for the center but I usually like to have both replaced at the same time. Also, if you are getting toner film build up on the hot roller, it iis time to replace that. If the thermistors does not correct the problem then replace the Power Supply Unit.
        • jake24482
          • Apr 2011
          • 116
          Doesn't hurt to replace both. The code is for the center but I usually like to have both replaced at the same time. Also, if you are getting toner film build up on the hot roller, it iis time to replace that. If the thermistors do not correct the problem then replace the Power Supply Unit.
          thanks guys let me order and i will let guys know
