Ricoh Aficio 3235 C - Black Band periodically
  • Zaxxon
    • 608
    Hi all
    Got this black band on the center of the image in the feed direction, when printing.
    Parts replaced:
    1. Black PCU
    2. Black Developer
    3. Imagetransfer (unit)
    Whats next? hw-power? LSU?
    Best regards
    Zaxxon
    20140314085642356(1).pdf
    Please start you post with brand, model, problem.
  • Zaxxon
    • 608
    Re: Ricoh Aficio 3235 C - Black Band periodically
    No one?
    • rthonpm
      • Aug 2007
      • 2859
      When you replaced the transfer unit, did you also replace the cleaning blade and cleaning unit? I'd almost bet you'd see that same streak on the brush in the transfer cleaner...
      • fredsp
        Product Specialist
        • Sep 2009
        • 14
        Have a look at your LSU
          • 37524
          Check the fusing unit.
          • Zaxxon
            • 608
            The error is very periodic.
            • Iowatech
              Not a service manager
              • 3930
              If the color of the band in the PDF is accurate as it appears on my computer (the machine I used for years recently bit the dust, and I haven't beat up the new one enough to be sure yet), that band appears to be process black, the approximation of black made by mixing the color toners. If that is the case, check your color PCUs and developers.
