ricoh 7001 jams code J13
  • rainmaker
    • Jul 2011
    • 77
    working on a ricoh 7001.it doesnt happened all the time,but when it jams it is j13.going to replace registration roller and white pressure roller and sensor.i am wondering if there is something else i need to replace.thanks for any input.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: ricoh 7001 jams code J13
    How many prints has this thing done?
    Hit it.
    • rainmaker
      • Jul 2011
      • 77
      450k on it
      • totoro
        • 568
        Have you cleaned the reg sensor yet? I've not had to change one in 6 years of working on this series.
        Totoro
        • rainmaker
          • Jul 2011
          • 77
          I have cleaned the sensor and roller.still jams,havent had it while I am there but it logs it
          • sandmanmac
            • 3983
            No experience with it myself, but the GG says that updating Engine Firmware to 1.63.04 or later helps with this particular Jam code
              • 37553
              sandmanmac is correct, according to Goose's Guide "update engine fw to 1.63:04 or higher". Also from Goose's Guide for the 2060, check for a piece of gum label stuck to rollers or guides.
              One other thing is to check for worn paper feed stations. Check the one way gears. Try swapping the first and third feed stations. If the problem goes away or shows up as a relay sensor in the feed stations, the original first feed station is the source.
              • tcs04
                FORMER Techie
                • 1183
                Relay Sensor clean?
                Dev leaking? (Kills feed stations AND Reg / Relay 1 way Bearings) Also Check for tight stepper motors on the feed stations.
                Reg Unit Mylar Guides can wear as early as 450K (Do you have an LCT fitted?)
