scan on windows 64 bits
  • claudioterrible
    no mercy...
    • Oct 2008
    • 96
    Hi everybody,i have a question,may be is stupid.does the old models like Aficio 2018,1035,2035, scan on windows 7/8 64bits? because i cant find these twain drivers in the ricoh sites,thanks for the help!!!!
  • CSI
    • Oct 2008
    • 73
    Re: scan on windows 64 bits
    For scan SMB, with win7 try with driver Win XP64. That's work
    With Win8 you must upgrade network firmware because microsoft add a new version protocol smb3.
    If Ricoh doesn't publish a new firmware "you must" scan to email but not to folder
    • claudioterrible
      no mercy...
      • Oct 2008
      • 96
      Originally posted by CSI
      For scan SMB, with win7 try with driver Win XP64. That's work With Win8 you must upgrade network firmware because microsoft add a new version protocol smb3.If Ricoh doesn't publish a new firmware "you must" scan to email but not to folder
      thanks csi!!! i will try,thanks!!!
      • sandmanmac
        • 3983
        None of those old models support smb scanning, firmware won't help that.
          • 37553
          For TWAIN scanning on 64 bit Windows, use the 32 bit driver with a 32 bit application or a 64 bit application ran in 32 bit compatibility mode. Those models that do have 64 bit drivers listed, it is the same driver as the 32 bit (version number, size, and rfg number). For SMB, I have heard that Win 8.1 has an update that allows you to turn off the feature that block older SMB equipment scanning to folder.
