RICOH MPC 3001 - SC 582
  • romnick
    • Aug 2008
    • 56
    Last month, I installed the machine,but today the customer called me to complain about SC-582 appearing on the control pannel. I tried to reset using 5810 but not success. how to solve this problem?
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: RICOH MPC 3001 - SC 582
    582 D
    IH inverter current error at power on
    The output current from the IH inverter does not reach the proper value
    when the IH inverter turns on.
    􀂃 Disconnected power input terminal 1 and 2
    􀂃 Defective IH inverter
    􀂃 Defective IH coil unit
    􀂃 Defective fusing unit
    1. Check the power input terminals 1 and 2.
    2. Replace the IH inverter.
    3. Replace the IH coil unit.
    4. Replace the fusing unit.
    I recommend a manual with the point to points to troubleshoot this!!!
    Mystic Crystal Revelations
