RICOH SP C820 fixing problem
  • tecnomarco
    • Jul 2011
    • 213
    Greetings all, I have a ricoh sp C820DN, I begin to have problems mounting, printing photos on the back of the toner does not adhere to the paper, I tried to change the fuser but the problem remains, I also have to reset the counter the fuser and the counter replacement PCU someone can help me. thanks
  • sandmanmac
    • 3979
    Re: RICOH SP C820 fixing problem
    Originally posted by JustManuals.com
    This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately after payment from:
    paul@justmanuals.com
    X2!
      • 37397
      Common problem when printing/copying to card stock or other thick paper. Make certain that the paper settings in user tools match what you are copying to, this includes paper thickness (Thick 1, Thick2, Thick 3 or Thick 4). Try thick 3 or 4 and see what happens. If you are using glossy photo paper, make certain that it is for use in laser printers. The glossy coating on ink jet paper can bubble and stick to the fusing parts. If you are printing, there is a setting in Printer Properties for paper thickness.
      • tecnomarco
        • Jul 2011
        • 213
        slimslob already done, setting the color with thick paper does not come off, it may be non-genuine toner that uses the client?
        • Herostrat
          • Oct 2012
          • 220
          Avoid using "for use toner" especialy on collor machines,it most certanly is toner problem,that fuser can't melt it propper.
          Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
          • CrapAimer
            • 296
            Remember to change the settings on the computer and the machine, its the computer that changes the machine speed not the printer
