Mpw2400 keep beeping after scan the original
  • Matoku
    • 173
    [Misc] Mpw2400 keep beeping after scan the original
    What is the problem with this machine. >>mpw2400 wide format>> after finish scanning the original and the machine keep beeping and the copy process not completed?
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Mpw2400 keep beeping after scan the original
    test the machine by copying A4 original from the bypass, use A4 paper.
    Nobody is perfect..
    • mikadonovan
      • May 2008
      • 2931
      A little more info would help. I have seen flat spots on the original exit rollers that cause problems
      NEVER ASSUME ANYTHING
      • slot
        • Jul 2008
        • 341
        try pressing the enter key then see what happens this may give you an idea of what the copier wants you to do eg is it set to sort?
        • Matoku
          • 173
          Hi,
          I have tried to make a copy in A4 size also the same.
          • Matoku
            • 173
            I have tried to press the enter button after scan the original but it nothing happen. The machine continue beepping.
            • Matoku
              • 173
              Originally posted by JustManuals.com
              Paul@justmanuals.com
              Dear justmanuals.com
              Actually I have the original copy of this service manuals and have go through it but there is no related topic about this problem.
              If any body have experiance with the problem are really appreciated if you can share you info.
              God Bless
              For your add info. this machine already runs about 270 k. and so far its work like a charm.
              But recently the problem accured.
              I tried do memory all clear and nothing improvement.
              • BLADE
                former propeller tester
                • 478
                whats with the hair straightning lol
                • rsyarcia
                  • 711
                  blade what do you think?
                  Nobody is perfect..
                  • Matoku
                    • 173
                    I let the machine sleep in the store and after a few month I return to look into this, I pulled all the harness and do memory clear then the problem gone. now it run again as normal/ Thanks
                    • rsyarcia
                      • 711
                      your lucky if your copy still ok after memory clear.
                      Nobody is perfect..
