MP CW2200
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    MP CW2200
    Looking for feedback on this wide format inkjet from Ricoh : MP CW2200
    Mystic Crystal Revelations
  • Vollegaaz
    • 73
    Re: MP CW2200
    well, what do you wonna know?
    I have a couple of them in the field, they run pretty good.
    If you're looking for great image quality or printjobs on special media, then there's better stuff out there.
    • Tonerbomb
      • Feb 2005
      • 2589
      Re: MP CW2200
      Is it a Ricoh engine or is it the Epson engine Ricoh used a few years back?? Had a customer inquire about these and I've never seen one...............
        • 37556
        Re: MP CW2200
        The Epson engines that Ricoh used a few years ago were the Stylist Pro 7700 and 9700.
        • Vollegaaz
          • 73
          Re: MP CW2200
          the Epsons are really good machines, very nice quality. The MPCw 2200 is a ricoh engine, same GW controller as the other Ricoh machines.
          Now we have the Ricoh "Mariage", latex printer, in fact it is a Mimaki engine, altough the printhead is Ricoh manufactered, great machine if you wonna print on special media like canvas...
          • Mick C
            • Mar 2011
            • 9
            Re: MP CW2200
            No it is not Epson, it is all Ricoh, I have a couple of machines in the field, had one call so far in 6 mos., black print head needed purging and it was fine, seems to run OK and good thing as it doesn't appear very service friendly !
            • andiamo
              Re: MP CW2200
              I have to put my 2 cents in on this one with the headache we've had with this printer. First off it is a workhorse we've been using it "against my recommendation to my boss" as our main plotter printing every set that goes out of our office. So in the six months that we've owned it we have run 49953 s.f. of black and white and 2902 s.f. of color prints through it. We have only had one breakdown and it was because we somehow got a blemish on our cutting blade. They had to replace it and we were back in business. But the problem that has haunted us since we purchased it. The paper catch tray is a nightmare. I would have not bought the machine had I known it was such a nightmare. It sits now like a broken childs toy in pieces. I have complained to Lanier and the Supplier and they just don't care. I would find a different machine for the simple reason that they took no time to design the paper catch tray. Other companies have figured it out I don't understand why they couldn't.
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                Re: MP CW2200
                We've had a few in the field for about a year or so now.
                The only calls we have had was to go and update the firmware to fix a possible ink ejection issue and help the customer with some print driver settings.
                We were initially a little concerned that the print heads would constantly clog up like on the smaller GX machines, but we have not had any print quality related problems to date.
                • Vollegaaz
                  • 73
                  Re: MP CW2200
                  true to that, i remember my first installation, did 4 hours for the main engine, and another 2 hours to figure out how to assemble the catch tray
                  Had a call last week from a customer who complained that large files cannot be printed trough the USB port (print from usb stick) witch is also an issue on other ricoh's, but just the day before there was a new firmware relaese to solve that problem, and it worked!
                  • Polarbear
                    • Feb 2012
                    • 1070
                    Re: MP CW2200
                    +1
                    not a bad machine, if only they would design the scanner and machine as ONE UNIT! What in the world does it have to be 2 frames and offset on top of it all! A full install takes 5 hours?? A similar HP is up and running in less than 2!
                    I also had visions about the GX horror of old but was assured that it is an all new system..... only time will tell.
                    Press the GREEN button!!
                    • mr.ricoh
                      • Aug 2012
                      • 9
                      length meter
                      I want to know about mpc 2200 max. scan length and print length
                      Thank you
                      • rexrotary
                        • Feb 2015
                        • 19
                        Re: MP CW2200
                        [QUOTE=Polarbear;413129]+1
                        not a bad machine, I have installed aroud 20 machine. I had the problem with new machine door open indication. I have replaced MCU board PCU but sitll the same problem. any body face same problem please let me know.
                        • Ollie1981
                          Toner Monkey
                          • Mar 2008
                          • 417
                          Just throwing my 2 cents in....
                          If you get an issue where this model will not go through the paper load procedure, I.e you push the lead edge into the feed unit and you feel like the machine grab the paper, then you drop the metal flap and it should then feed the paper through right past the head so the "dress" sensor can measure the width, if you drop the flap, the fans spin up and the machine just lets go of the paper and/or indicates a jam then.....
                          .....horizontal encoder strip, I had a most unfun time with one of these where it was stubbornly doing exactly that, there is a small black bracket towards the left hand side of the carriage that the encoder strip should sit on top of, on this machine it was in front of it and the head had damaged the strip. luckily you can mount the strip back on upside down and that fixes it
                          .... If you get this there will be no SC code or jam code that indicates the encoder or the head in any wY.
                          • mercer
                            • Sep 2015
                            • 7
                            Re: MP CW2200
                            We have had one sitting idle on our showroom for over a year. Now they are trying to move it but I cannot get it to print from the cyan print head. We have done the cleaning and flushing several times with no luck, has anyone messed with the print heads on this unit?
                            • mikadonovan
                              • May 2008
                              • 2931
                              Re: MP CW2200
                              A relevant link......
                              http://www.copytechnet.com/forums/ri...ht=#post559946
                              NEVER ASSUME ANYTHING
