Mp 2250b works with everything except web monitor
  • COPIERMAN
    • Jun 2009
    • 559
    came from Government location I can do everything except get to the web monitor of copier. does anybody know what i have to do for this . i have post this on connectivity also. check what they said but no luck. So i decide to try on tech side to see if someone knows about this
  • HDSB
    Field Tech
    • Feb 2013
    • 64
    Re: Mp 2250b works with everything except web monitor
    format the hard drive?
    • elamurugu
      • Mar 2014
      • 27
      you take HDD mp2250 and copy HDD.
      • GromBG
        • Oct 2010
        • 24
        Just copy NVRAM from unlocked MP2550b and problem is solved,that issue dont have anything with HDD
        Best regards
        • rthonpm
          • Aug 2007
          • 2859
          Try changing SP 5-985-001 to 1 and rebooting.
          You said in your Connectivity post that you did SP 5-801, for a memory all clear, that's always asking for trouble...
          • MOSSY BOY
            • Aug 2010
            • 16
            Try adjusting Security settings .....
            User Tools , Admin tools, System settings, Network security Level, to " 0 \ Zero"
            This should clear \ open all ports within Network Security.
            Hopefully you should be able to connect then.
            Try another browser ??
            Is the device configured to HTTPS ?, possibly a security certificate installed ??
            • COPIERMAN
              • Jun 2009
              • 559
              Hi everybody
              i finally got it with help from suggestions was in copy/doc tab menu protect was level 2. i had to turn on admin mode first to log in. went back to copy/doc tab and change it to level 1. Thanks again for everyone's help.
