Aficio 2075, resets itself!!!! (counter 0)
  • Codex
    • May 2008
    • 704
    [Misc] Aficio 2075, resets itself!!!! (counter 0)
    Hello
    I have a very strange problem. A customer called me last week, the machine has an SC 870 (Adress book Error), no other problem. I asked for the counter and he said "zero"....., first i thought he was kidding, he prints out the counter and send it via fax.....the counter was really "Zero", no serial number, no support phone number, nothing!!!....The machine works fine, till this morning...the customer calls me and the counter is again "zero"!!!.
    Any ideas??
    Memento Audere Semper
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Aficio 2075, resets itself!!!! (counter 0)
    Sounds like a typical faulty NVRAM: B064 9099
    • vargue
      • Oct 2011
      • 404
      i think is hdd error try to format hdd if it's no avail.swap with another hdd. next as ruben said nvram next change firmware
        • 37533
        I tend to agree with Ruben. NVram can cause loss of counters and also SC 870. HDD cannot cause loss of counters. See if you can print the all SMC reports and get a closer estimation of what the actual counter might be, I.E counters in jam history or SC history. Back up what you can of the NVram and replace it.
        • Codex
          • May 2008
          • 704
          Ok.. Replaced nvram only, let's see what's happening..... Thanks!
          Inviato dal mio GT-I9100 utilizzando Tapatalk
          • Zoran
            • 51
            repair nvram
            • Codex
              • May 2008
              • 704
              Wow! Great work!
              Inviato dal mio SM-G935F utilizzando Tapatalk
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Doesn't AF2075 have a mechanical counter anyway for redundancy?
                From the manual:
                This machine has an electronic counting device that uses software to monitor thenumber of copies. In addition to the electronic counter of the NVRAM on the
                controller board, the machine is also equipped with a mechanical counter.
                • bob marley
                  • Jan 2012
                  • 1339
                  I agree with Ruben and slimslob . seems u need to replace NVram
                  Live for yourself and you will live in vain. Live for others, and you will live again
                    • 37533
                    From the manual:
                    It is behind the inner right cover that is located to the right of the transfer belt unit. There is a cover stick over it. SP 5915 if set to 0 will disable the mechanical counter. If it is disconnected, say by a customer, without being disabled, SC 901 will occur and copying/printing will be prohibited.
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      Just thought that even if he has to replace the nvram at least he can still have a valid counter available.
                      • Zoran
                        • 51
                        When the battery voltage in NVRAM falls below 2.7v reset the machine - goes off when entering into sleep mode.
                        When the voltage is below 2V reset the counter copies to 0,000,000 ip address of time ...
                        Replace nvram or repair
