Fusing Unit Modifications
  • Richariri
    • Dec 2013
    • 163
    Hello All,
    Has anyone had any success converting the printers fusing units to fit a colour copier?
    E.G. We currently convert the SPC811 (402719) Fusing units by switching over a couple wires, this then enables it to be used in an MP C35/4500
    What I'd like to know is whether or not I can do the same or similar procedure for the MP C40/5000 and/or MP C55/6001 using the printers fusing units.
    I'd expect that the SPC820/821 fusing unit (403119) will fit a 4000 / 5000
    and an SPC830/831 fusing unit (407099) will fit a 55/60/6501 ???
    Has anyone had any experience converting fusers for these units?
    if so, what procedure do I need to do?
    I have had a quick search on here, but can't find anything definitive.
    Thanks in advance. :-)
  • techsass
    • Dec 2010
    • 248
    Re: Fusing Unit Modifications
    I've used the SPC820 fuser on the c5000. Same procedure - move the pin over 1 slot to match the copier.
    • daveyt
      • 15
      hi there, yes we convert the SPC820dn fuser to an MPC5000, by changing over the link pin.
      • Richariri
        • Dec 2013
        • 163
        Thanks guys, just what I wanted to hear.
        If I compare an original fusing unit with the printers can I see the wire that needs switching and just copy the original fusers layout?
        If it's 100% exactly the same as converting a SPC811dn then we're onto a winner.
        I'm interested to hear on what the copytechnet community prefer to do and what's cheapest... rebuilding a fuser or replacing with converted model?
        • Richariri
          • Dec 2013
          • 163
          also, is there a difference between me using the SPC820 vs the SPC821
          I understand that the 820 is for 40ppm and the 821 is for 50ppm does this still apply when converting them? or should I just get the 821 and use it in both?
          feeling confused
          • daveyt
            • 15
            We use the SPC820 on both the MPC4000 and The MPC5000, as far as cost goes, the whole 820 fuser is NZ$603, and the parts to refurb are NZ$612, so cheaper to just replace it.
            • Richariri
              • Dec 2013
              • 163
              ok, just a couple more questions and I'm satisfied (maybe)
              If the converted SPC820 fits the MP C4000/5000, does that mean it will definitely work in an MPC2800/3300?
              Also, is there a better/cheaper option to rebuilding the MPC3000 fuser?
              • Bantams
                • Jun 2012
                • 603
                No the 2800/3300 and the 2500/3000 Don't the same fusers as any of the Printer models you have to refurb them but it dosnt take as long to do as the mpc4500 or 5000 ranges.
                • Richariri
                  • Dec 2013
                  • 163
                  Thanks that's spot on.
