Ricoh SP C221sf How to Enter Service Mode
  • rich1106
    • Feb 2014
    • 21
    Hi!.
    I have a Ricoh sp C221SF for my personal use but for a while I can not copy or print in color and do not know how to enter the service mode to adjust colors. I tried in the same way that other models (Clear 107 and Clear / Stop) but does not respond.
    If someone could help me and tell which is the key sequence to enter would be very grateful.
    • 37550
    Re: Ricoh SP C221sf How to Enter Service Mode
    First, since you do not know the proper sequence for entering Maintenance Mode, I will assume that you do not have a service manual manual. You will need one to do any adjustments.
    Second, were you ever able to copy and print in color?
    • RandyW
      • Jan 2013
      • 213
      "Color degradation may occur in color printing after the machine is moved or a large number of pages are printed. In this case, adjust color registration by executing [Color Regist.] in [Machine Settings]"
      that's from the User Manual.
      • wfinn
        • Mar 2011
        • 70
        For this model you need software loaded on laptop for service. Resetting a fusing code is same way. Have to go through the software and there are some areas that require a password too. Btw this password is not in the manuals but I believe it did finally make it to Goose Guide.
          • 37550
          This would be true if he has a printer only version. Since he talks about not being able to copy in color it is most likely the MF version.
