Ricoh MPC7501 SC364
  • bridgeoverriver
    • Apr 2014
    • 24
    [Error Code] Ricoh MPC7501 SC364
    Printer was working normally until a I completed a HDD format, this was done to remove Equitrack, since formatting the HDD, I get the message SC364 after printing 10 or more pages, this refers to the TD sensor in the black PCU. my question is after completing a HDD format do I need to do anything, or do I need to replace the PCU as stated in the service book or is it giving a spurious code since doing the HDD format.
    Regards Malcolm
    • 37533
    Re: Ricoh MPC7501 SC364
    You should be able to replace the density sensor. Check if there is a part number on the sensor itself and order that part. You will need the mounting tape for it also. I have done one on a C6501 and it worked. A lot less expensive than the development unit.
    • bridgeoverriver
      • Apr 2014
      • 24
      Thanks SLIMSLOB
      Would you happen to have the part number for the TD sensor, I cant find it listed in the parts catalogue.
      Regards Malcolm
        • 37533
        Originally posted by bridgeoverriver
        Thanks SLIMSLOB
        Regards Malcolm
        It is not listed in the part catalog. You have to look on the sensor currently in the machine.
        • SargeNZ
          • May 2012
          • 263
          For future reference, Equitrac can be uninstalled via the 'Extended feature settings' in User tools.
