problem with AF1075 printer installation on MAC OS
  • KM7155
    • Aug 2008
    • 146
    Hi,
    i have problem with the X OS 10.9, it can't find the printer model.
    i try to download the driver but its only PPD file, which my 1075 did not have
    ps chip.
    any help?
  • rthonpm
    • Aug 2007
    • 2859
    Re: problem with AF1075 printer installation on MAC OS
    You're going to need PostScript for any kind of substantitve and reliable printing with Macs. No getting around that...
      • 37532
      If I remember correctly, the 1075 has to have PS3 to work with Apple.
      • KM7155
        • Aug 2008
        • 146
        thanks for the input.
        but my 1075 dont have the ps chip, can i use the generic printer from the mac?
        because one of the Mac able to find the 1075, and can print properly.
        • Amos Kaplan
          • Nov 2013
          • 9
          Yes, you can create a "Generic Printer" with certain versions of OS 10.x, but it will be limited. The PS chip is truly the only proper way.
            • 37532
            For a 1075 the generic PCL driver is fine. For a color machine, it only supports b/w printing.
            • Barış KURT
              • Jul 2010
              • 72
              I have running at MAC OS without PS3 module ,on MP C2551.
              click here
              macosx/macosx | The Linux Foundation
              Set on MAC
              1- pxlmono-1.9.dmg install
              2- Foomatic-RIP 4.0.6 install
              3- gplgs-8.71.dmg install
              4- hpijs install.
              5- On mac OS ,select SOCKET HP JETDIRECT .Enter printer Ip.
              6- Select printer HP Color LaserJet 8550 hpijs pcl3, 3.10.6.15 PXL-PCL 3 driver.
              regards.
              Black is Kyocera , Color is Gestetner.
