MPC 4502 SC 553
  • rhe
    • Feb 2013
    • 51
    MPC 4502 SC 553
    Dear All
    i have machine with error code sc 553,machine has two reset mode 5810-1 and 5810-2.with the second mode high temperature will be reset.before doing that need fix fuse in fusing unit so that machine detect new unit. i have changes heat sleeve unit along with fuse but still i can't reset it with 5810-2 it gives fail on the display.
    anyone has any idea
    thanks
  • lolways
    • 5
    Re: MPC 4502 SC 553
    Check out the attachment, Hope it helps, if i've done it right
    • rhe
      • Feb 2013
      • 51
      Re: MPC 4502 SC 553
      Thank you brother ,this i already did anything else.
      thanks
      • Debs1964
        • Oct 2010
        • 1693
        Re: MPC 4502 SC 553
        SC553 is not one of the overheat service codes that needs SP5810-2 to reset, you should be able to reset it by entering SP mode, then powering off/on as long as you have resolved what caused the problem in the first place
        There are 10 types of people in this world, those who understand binary maths and those who don't
