Drum Type 1315
  • Makaza
    • Aug 2025
    Drum Type 1315
    Hello .I need to replace td sensor from drum model Type 1515 replace in drum model type 1305 how i can do that is need to change some wires or ?
  • rthonpm
    • Aug 2007
    • 2859
    Re: Drum Type 1315
    Just get a new PCU. The 1515 has a user replacable PCU so there are no service parts for it. If it's relatively new, you may be able to get a warranty on it, but that's tough to do.
    • Makaza
      Re: Drum Type 1315
      i need for ricoh 1305 only td sensor if you how to remake td sensor from ricoh 1515 pls help
        • 37533
        Re: Drum Type 1315
        What makes you think that you need a new toner density sensor? If the machine keeps indicating that the toner needs to be replaced, either the bottle is not rotating or the gears on the development unit are striped and you will need to replace the PCU (common problem for this model).
        • Makaza
          Re: Drum Type 1315
          i need td sensor only and i ask how to make td sensor type 1515 work on ricoh 1305
          • Makaza
            Re: Drum Type 1315
            Any help
            • sandmanmac
              • 3981
              Re: Drum Type 1315
              Originally posted by Makaza
              Any help
              Man...you don't give up do you?
              Here's a question...have you even tried it?
              If it doesn't work as is, then it won't work. PERIOD
              • kopirmaster
                • Apr 2011
                • 70
                Re: Drum Type 1315
                its pozible but how ?
                • Makaza
                  Re: Drum Type 1315
                  i only change one wire and work
