Add Toner
  • Gench
    • Aug 2025
    Add Toner
    I have a LD445c with an add tone condition on black. I've replaced the pump, toner and developer clutches. Opening and closing the door will cycle the toner and be ok for about 500-1000 copies, then the add tone condition comes back. Any ideas?
  • sandmanmac
    • 3983
    Re: Add Toner
    Blockage in the hose restricting the flow?
    • Gench
      Re: Add Toner
      A new hose comes with the pump, but I guess there still could be a blockage.
      • sandmanmac
        • 3983
        Re: Add Toner
        Yes it does. Just not everyone always replaces the hose at the same time.i think you can rule that out then
          • 37553
          Re: Add Toner
          Check that you did not get the hose pinched or kinked when installing. Check the maintenance counters on the black developer and unit.
