"Please add toner"
  • jrob416
    • May 2011
    • 112
    [Misc] "Please add toner"
    I have been working on a MP 5001 with an intermittent "add toner" message. I swapped the toner hopper with another machine, with no change. Changed developer as it was called for by the pm count, and I figured it might help the add toner problem also. No joy. The drive gears on the dev. box are good and everything rotates as it should. What am I missing? Could it be a bad sensor in the bottom of the dev. box? Please help!
  • rthonpm
    • Aug 2007
    • 2847
    Re: "Please add toner"
    Toner motor turning? Also, check the VSP and VSg readings and see if the machine actually is reading at a level that it should be calling for toner. I've mainly seen it with older machines, but I have had instances were an add toner prompt wouldn't clear without completely reflashing the firmware.
    • TonerMunkeh
      Professional Moron
      • 3865
      Intermittent add toner issues can be caused by the paddle mylars falling off the inside of the toner hopper, I know you said you changed it with another but there's nothing to say that one didn't suffer from the same fault. Are you using OEM toner / dev? Are you getting good readings from your ID and TD sensors?
      Hit it.
      • hossam
        • Aug 2010
        • 70
        Try to disconnect toner hopper sensor socket, close the door, if the message gone make a test page, if it's good so it might be that sensor problem
        • takis
          • May 2014
          • 1
          toner motor is off......
