Ricoh 8001sp
  • Old Crow
    • Aug 2011
    • 203
    Ricoh 8001sp
    Tandem drawer jams at reg. rollers and kicks down B2 guide plate. Removed feed unit and cleaned one way bearings and shafts and replaced p/f/s rollers, no help. Cleaned all rely/transport rollers, one ways and sensors. Drawers two and three feed fine. Played around with guide plates at reg.rollers, seem to remember this caused similar problem on a mp5500. Any help appreciated, going back tomorrow. This customer has little patience! Thanks...
    • 37533
    Re: Ricoh 8001sp
    Try swapping the first feed unit with one of the other trays. If the problem moves with the feed unit, the problem is in the feed unit.
    You did not tell us what the jam code was. This is the first thing to know when trying to fix jamming. If it is a one way gear, TSB 018r has a table that will tell which one to replace base on the jam code (8,9,10, and 12). If it is a J53, replace the torque limiter.
    • Old Crow
      • Aug 2011
      • 203
      Re: Ricoh 8001sp
      Thanks for the reply, the majority of the jams codes are 12. I guess I wasn't thinking straight as it never occured to me to swap the unit. I can't find that technical bulletin anywhere, there is a TSB18 but I have seen 018r. Any chance of getting that from you somehow?? Thank again.
      • Bantams
        • Jun 2012
        • 603
        Re: Ricoh 8001sp
        You have cleaned all the paper dust that's probably covering the reg sensor that's under the metal plate under the dev unit right?
        • Old Crow
          • Aug 2011
          • 203
          Re: Ricoh 8001sp
          Yes and there was a lot of it. Cleaned reg rollers also. Again, drawers 2 and 3 work ok.
          • Amos Kaplan
            • Nov 2013
            • 9
            Re: Ricoh 8001sp
            Are you leaking Developer? If so, replace all one-ways in feadhead.
            • Old Crow
              • Aug 2011
              • 203
              Re: Ricoh 8001sp
              No dv leaking. Does replacing all one way bearings usually cure that? How about sensors too?
              • Max
                • Oct 2011
                • 561
                Re: Ricoh 8001sp
                Check the vertical plate. Make sure the relay rollers have enough pressure to feed the paper.Had it a few times now where the plate was warped or the locking mechanism was bent.If memory serves me well there are two sets. The top may be ok but the bottom once not.
                • Old Crow
                  • Aug 2011
                  • 203
                  Re: Ricoh 8001sp
                  Are you talking about the metal guide plates with mylar strips on them? They look ok, I tried forming them one way then the other. The lead edge of the paper gets into the nip of the reg rollers so if you turn the rollers the paper advances forward evenly.
                  • Herostrat
                    • Oct 2012
                    • 220
                    Re: Ricoh 8001sp
                    What's the condition of gears anyway?
                    Happened more than once that waste toner bottle sensors fail and owerflow on pick-up gears.
                    Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
                      • 37533
                      Re: Ricoh 8001sp
                      Jam 12 from tray 1 is the smaller of the two gears that are on the same shaft. New part number AB011491.
                      • Old Crow
                        • Aug 2011
                        • 203
                        Re: Ricoh 8001sp
                        The gears don't look dirty from toner or dv, but machine does have 1.1 mil on it. Thanks for the part number, do you think I should replace others also? Thanks for all the replies.
                          • 37533
                          Re: Ricoh 8001sp
                          One way rollers of the gears just get worn out after a while. 1.1 mil is about where the first relay clutch on the Aficio 550s and 700s would have to be replaced. Same symptom, late jam at the registration sensor.
                          • Old Crow
                            • Aug 2011
                            • 203
                            Re: Ricoh 8001sp
                            I'll replace all of the one ways and the relay cl. thanks again for all the help!
                            • Old Crow
                              • Aug 2011
                              • 203
                              Re: Ricoh 8001sp
                              just a follow up to this problem. I replaced all of the guide plates with mylars and this did the trick. I guess the paper fed ok from drawers two and three because the paper is coming straight when the lead edge hits the reg rollers as opposed to coming from an angle from the top feed unit. thanks for all the ideas and suggestions with this problem.
