user codes on windows 8
  • wilbert.c
    • Apr 2014
    • 24
    i installed mp 1600 printer drivers on windows 8 machine but trying insert codes from printer properties to preferences then valid access , after programming trying check the code under valid access and the code is no where to be found . all other window 7 computers are able to print using user code but windows 8 is not . tried to delete the driver and reload but to no avail . I greatly appreciate your response in advance
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: user codes on windows 8
    Which printer driver have you installed?
    Hit it.
    • tankmurdock
      • Apr 2014
      • 13
      To my knowledge in Windows 8 the user codes are input from the Printer Properties section of the driver under Advanced Options. Select the Driver Encryption and then Encryption Code would be the user code. Should not have to enter the code anywhere else. If it won't save the code you input then it could be a permissions issue since this is under the Printer "Properties" and not the "Preferences". You have to have elevated rights to administer Properties especially in the super duper locked down Windows 8.
      • sandmanmac
        • 3985
        Just installed MP1600 PCL5e driver on Win 8, and set the user code exactly as you described, and used it to print to an MP161 -no issues
