MPC4503 and 5503 paper curling
  • Smee
    • Aug 2009
    • 178
    Hey guys, Im seeing paper curling a lot on the new 03 range. So far the fix is to put on the modified paper exit trays so it stacks nicer - but it dosnt stop the paper curling.
    Before anyone says its damp paper...its not. Fresh reams do it too, turned both ways around! Ive also played around with fuser temps with no fix, and updated firmware.
    Its gotta be happening everywhere, anyone got any fixes?
    Cheers.
    • 36796
    Re: MPC4503 and 5503 paper curling
    Your profile does not show where you are from so we cannot know what the temperature and humidity is like there. It takes only a couple of hours for paper to pickup moisture. Usually shows as the first 8 to 10 sheets out of the paper tray in the morning coming out curled. I have had customers where the curl was enough that the paper rolled it self into about inch and a halt diameter tubes. Even "fresh reams" that have been stored where they are exposed to cold and/or humidity can absorb moisture, unless the wrapper provides a full moisture barrier. Try turning on the Anti-condensation heater SP5805.
    • Eric1968
      • 2458
      Ricoh provides a tool to measure the amount of moisture in a ream of paper (unfortunately I don't know the part number..). It should be between 35-45%. I've measured 55% and higer in "fresh reams" of paper.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        It isn't damp paper for these, it is a terrible paper exit path. They have additional small rollers to counter this but they are ineffective. It happens less with a bridge unit, but that could be an expensive solution.
        • Big Durbs
          • Sep 2012
          • 16
          we are seeing the same problem , and also on the new black and white 03 range as well , we have tried all sorts of fix's , "tweaking" the input guide on the finisher sometimes helps but not always .
          • turbojetboy
            • Aug 2009
            • 279
            Have a look at this bulletin, regarding feeder issues. Note the settings and talk re paper curl.
            • Smee
              • Aug 2009
              • 178
              We must get different bulletins from you guys...havnt seen that one. Im gonna give those SP's a go, cant hurt. Will update with the results!
              Thanks!
              • tonnerboy
                • May 2011
                • 212
                Good morning everyone.
                I have been having the same problems. And now that winter is here, major problems will arise. I have hundreds of equipment Metis series.
                The suggestion to activate the SP 5805 applies only in the case of equipment that have the "Anti-Condensation Heater". If you do not have this option enable this SP is useless.
                The equipment installed in the south of Europe "Anti-Condensation Heater" is optional.
                I agree that this is one of the solutions to the problem, however a change in the output paper tray decreasing the drop of the paper will be less expensive
                • Zeldaman
                  • Mar 2011
                  • 946
                  • ewizzy
                    Dirty toner monkey
                    • Feb 2014
                    • 55
                    I had a similar problem on a MPC 4503. Paper was curling and jamming all the time, I spoke to Ricoh technical and they said its to do with the "Green" fuser technology. However. I have updated the firmware in a number of these machines with Firmware dating from around July this year, and it has pretty much stopped any curling issues.
                    Depending on when you updated the firmware, I would emphasise the need to make sure ALL firmware is updated to the latest firmware possible, see if this helps.
                    Alex
                    • Big Durbs
                      • Sep 2012
                      • 16
                      Alex
                      Thanks Alex , I think we have and its gone all quiet on the western front :-)
                      • Polarbear
                        • Feb 2012
                        • 1070
                        Hi
                        You can also enable curl correction on these models:
                        1113 [Curl Correction]
                        001
                        Execute Pattern *ENG
                        [0 to 2 / 0 / 1/step]
                        0: OFF
                        1: ON(No Decurl)
                        2: ON
                        Enable/disable curl correction.
                        Press the GREEN button!!
                        • ewizzy
                          Dirty toner monkey
                          • Feb 2014
                          • 55
                          Great news!
                          • ewizzy
                            Dirty toner monkey
                            • Feb 2014
                            • 55
                            Originally posted by Polarbear
                            Hi
                            001
                            0: OFF
                            1: ON(No Decurl)
                            2: ON
                            i noticed no improvement using this code. If anything, it made the jamming worse, and didn't noticeably correct any curl.
                            Firmware re was the fix for my machines.
                            • tonnerboy
                              • May 2011
                              • 212
                              Thank you all for the answers.
                              I will check if the firmware is updated.
                              By the way, can you give me the version of firmware that fix the problem?
