Gestetner DSM41f helpppp..
  • Joshua Herrero
    • Sep 2025
    Masters, can someone help me find drivers or software for this machine? Gestetner dsm415f, it is bought second hand and don't have any cables or any drivers present.. is there any downloadable software for these? pls help.. badly need it tnxxx
  • Gift
    • Mar 2011
    • 2459
    Re: Gestetner DSM41f helpppp..
    try the manufacvturer homepage for drivers and manuals, plan b: google is your friend - searching for the model number will lead you to the download page
    • Joshua Herrero
      hompage of the manufacturer is down.. i cant find it in google also, no exact drivers or software..
      • Chrisrayburn
        • Jul 2012
        • 7
        301 Moved Permanently
        • Chrisrayburn
          • Jul 2012
          • 7
          Sorry that should say ricoh-usa.com
          • Joshua Herrero
            gestetne drivers are not available on the site u had given... tnx
            • Luther
              • May 2006
              • 682
              its a ricoh 1515, thats what it crosses to, use the 1515 ricoh driver
              • Bantams
                • Jun 2012
                • 603
                try www.ricoh-support.com also the 415F doesn't have a printer option on it does it?
                • sandmanmac
                  • 3991
                  Correct Bantams! The Gestetener DSM415F / Ricoh Aficio 1515F were copy and fax only, and not upgradeable.
                  • Joshua Herrero
                    are you sure sir that it don't have print option? because it is only bought second hand, and my boss would like to install it to a computer so that they can able to print files.. tnx
                    • Joshua Herrero
                      i don't know sir if it does have print option, i was only told to do install this printer into a computer... does 41f don't print? so if that would be the bases i will tell my boss that this machine cannot print.. thank you sir
                      • Tonerbomb
                        AutoMajical Resolutionist
                        • Feb 2005
                        • 2589
                        the "F" in the model indicates it is copy and Fax, no print scan.
                        Mystic Crystal Revelations
