Transform an Aficio 2045 in an Aficio 2045E
  • Codex
    • May 2008
    • 704
    [Misc] Transform an Aficio 2045 in an Aficio 2045E
    Hello
    I have a customer that needs to have Scan to folder... But he have only an Aficio 2045, with his machine he can only scan with Scanrouter.... But he needs to scan to a server with Windows 7 that didn't support Scanrouter software.
    We have an old broken Aficio 2045e, the "E" series support scan to folder, the machine turns on and the controller seems to be ok.... Now I'm wondering.... If i swap the controller, bicu and ipu with the customers 2045 i'll be able to use scan to folder?
    Inviato dal mio GT-I9100 utilizzando Tapatalk
    Memento Audere Semper
  • sandmanmac
    • 3981
    Re: Transform an Aficio 2045 in an Aficio 2045E
    Originally posted by Codex
    Hello
    Might that work? yes, it might.....but why would you want to get involved in that nightmare?
    The machine is old and outdated. Why try to put 'lipstick on that pig'?
    If there was ever a candidate to upgrade to something newer and more compatible, it is this end user.
    What is broken on your "E" version machine? Is it just normal things like fuser, drum, etc. I would suggest it might be a better option to put the consumables from your end user machine in the "E" version machine.
    Otherwise....You have 3 options in my opinion:
    - Scanrouter (I hate even saying that word!!) can actually be installed on Windows 7 with some minimal tweaking -I've done it dozens of times. Search the forum
    - Setup scan to email on the 2045
    - UPGRADE MACHINE (my personal favorite)
    • Codex
      • May 2008
      • 704
      Hello
      thanx for the answer
      The problem is that this customer "loves" his machine....... Can you explain how you set up scanrouter on a Windows 7 environment? Thanks!
      • Codex
        • May 2008
        • 704
        In the "E" series machine the only thing that works is the electronic part....
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          I seem to recall this can't be done because some of the electronics are different between the "E" and the non E machines..............
          Take sandmanmac's advise, UPGRADE the customer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          Mystic Crystal Revelations
          • sandmanmac
            • 3981
            Hello
            As I said, I already have several times on this forum.
            You ever hear of google?
            • Eric1968
              • 2458
              Hello
              This machine belongs in a museum. It's old and it doesn't support today's hardware and operating systems. It's the same as trying to upgrade a 30 year old car to run on electricity, it won't work...
              (BTW, Windows 7 is not a server operating system).
              • Bantams
                • Jun 2012
                • 603
                You can make a 30yr old car run on Electricity I've seen it done In Back to the Future lol
                • Codex
                  • May 2008
                  • 704
                  I agree on that... I only try to help this customer, i know that Windows 7 is not a server OS....
                  • Codex
                    • May 2008
                    • 704
                    ... Yes of course :-).... Thanks for the help.
                    I let you know
