Printer Driver
  • coolgreen
    • Sep 2012
    • 7
    Printer Driver
    Hello,
    Anyone know how the ricoh driver with user codes, ask for the code after printing ?
  • cwilson
    • Jun 2012
    • 50
    Re: Printer Driver
    go into the driver, under preferences, then valid access. put in the user code they use to make color copies.
    But I cleaned the scan glass.......
    • coolgreen
      • Sep 2012
      • 7
      Re: Printer Driver
      I know, but i need driver ask me a code after click print with popup window. In this case, computer is used by a lot of users. Each user has a private code and sharing the same account on windows.
      I have toshiba machine in office and appear department code with popup.
        • 37376
        Re: Printer Driver
        Download the newest driver and unzip it. Before installing it, use the Ricoh Print Driver Editor and modify the driver. Ricoh no longer makes the PDE available on their driver page but you can search the internet. Just google "Ricoh print driver editor".
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Re: Printer Driver
          go with slimslob's advice for this, he's dead on !!!!!!!!!!!!
          Mystic Crystal Revelations
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Re: Printer Driver
            X2!!!!!!!
            • coolgreen
              • Sep 2012
              • 7
              Re: Printer Driver
              I think we already got. Tomorrow I'll test.
              Thank you all for the help.
              • Richariri
                • Dec 2013
                • 163
                Re: Printer Driver
                Hello everyone,
                going to throw my relevant question into the mix.
                I have a customer who wants to have the usercode pop up on feature across all their PC's. They have a mixture of windows XP and windows 7
                I have developed the custom driver for windows XP, tried and tested perfectly.
                I then did the same procedure for our windows 7 PC and the popup box does not appear at all after print is sent.
                I cant approach the customer with their amazing custom drivers that only happen to work on half their PC's
                to clarify, It works on XP but not on 7
                Details:
                I have only tested with word 2007, will test with another program when the windows 7 PC is free.
                I have only changed the default from colour to b/w and clicked the tick box for user-code pop up.
                I have done the procedure with both the outdated 'print driver editor tool' and the over complicated but supported 'printer driver packager NX'
                The machine is an MP C3001 and the driver is PCL 6.
