Hi !
Im facing some problem when i using A3 size print in Tray 2,3,4 in MPC2500. it come out Paper Crumple.
But using A4 paper Size in Tray 1,2,3,4. No Problem.
When i use A3 paper size in Bypass, it show no problem and no crumple.
I change the Paper Feed Roller in Tray 2,3,4 , Change the Entire Duplex Unit, Change the Transfer Drum Belt, Change the Transfer Roller (not new). But still paper crumple by using A3 paper size.
The A3 paper size are using 70 gram and if i use in MPC5000. No problem at all. But if i use in MPC2500, it show paper Crumple.
If i use the A3 size 80gram (Double A) Paper in MPC2500. No problem at all.
I dont know happen, is it because of the Magnetic Clutch problem?
Please enlighten me.
Thank you
Thank you
