Aficio SPC242 with communication error 200082
  • Sharpshooter
    • 21
    comm error 200082.jpgHi people.
    What does Communication error 200082 mean?
    My customer gets it everytime she gets a fax from a special sender.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Aficio SPC242 with communication error 200082
    From the user manual:
    2XXX32 to 2XXX84 An error occurred while receiving a fax.
    • Confirm that the telephone line is properly connected to the machine.
    • Disconnect the telephone line from the machine, and connect a standard telephone in its place. Confirm that you can make calls using the telephone. If you cannot make calls this way, contact your telephone company.
    • If the problem persists, contact your sales or service representative.
    Not very helpful, you may have to lower the communication speed or use an older protocol.
      • 37491
      If the customer only gets it from a couple of senders and most receive without a problem, the problem is most likely with the sender's machine or phone line. One example that I can think of is a phone line that is a DSL and does not have the proper filter on the jack where the FAX is connected.
