Need Help Doing Java On Metis Range
  • garryayling
    • Jan 2011
    • 21
    Hello just need some info. Ive never had to do java before on the 03 range. Was just wondering if anyone was able to give me a step by step instructions on how to do as this range has no sd card to install on. just need to no what files and format I need and where to do it. Ive downloaded the java but cant seem to figure how to do it...
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Need Help Doing Java On Metis Range
    http://www.copytechnet.com/forums/ri...procedure.html
    • garryayling
      • Jan 2011
      • 21
      Sorry that's not the help I need. I need help for the Metis range that is for older models. Do u have an upto date bulletin.
        • 37251
        If you have the Smart Operations Panel, JAVA or actually the iSDK needed to work with the android OS, is not yet available the last I heard. If you have a standard operations panel, JAVA is imbedded on the controller board. You may have to check if it is enabled with SP 5730-002. You can also enter User Tools. If extended features option is there press it and see if JAVA is started, should show starting. JAVA does not have a function button. You have to install JAVA apps and add them as icons on the Home screen.
        • garryayling
          • Jan 2011
          • 21
          Sorry I understand all that it's updating java I need. Sorry if I've worded my problem wrong.
          • paulg
            • Jun 2007
            • 278
            There are two ways to install Java on 03 devices.
            Either use Remote install manager to load on EDC file or
            If you have the UPD file get a sd card wipe off all other data. Then unpack the upd file and then browse down untill you see the upd file and the two text files. Double click the upd file then you should get a folder with a name like ver11.19.03 open this folder you should see a folder called sdk. Copy this folder on to the SD card and put the sd card in the lower service slot and power up the 03 device.
            In the lower left hand part of the screen you should see how it is getting on.
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              If the device has access to the internet, it might be easier just to use the built in firmware update tool in Service.
              Also, why bother? Updating Java rarely fixes anything.
              • garryayling
                • Jan 2011
                • 21
                Thanks for the help.
                • slot
                  • Jul 2008
                  • 341
                  just follow what paulg said I have updated a few copiers with equitrac and safe com installed when you do this change the copier priority from the app back to copier this speeds up the install.
                  ruben can you shed some light on the comment about the copier being on the internet to do the firmware thanks in advance.
                  • ruben
                    The New Guy
                    • Oct 2012
                    • 1203
                    Go in Service Mode and press the Firmware Update button. You can set a time and date to pre-download the firmware package, then once it has downloaded return to the same menu to initialise firmware update. If the button doesn't exist you may have manually update first.
                    • tittalwax
                      • 4
                      Updating java is crucial for 3rd party software ie. Global Scan NX. To do firmware update from service mode the machine has to have a @remote number.
                      • Tonerbomb
                        AutoMajical Resolutionist
                        • Feb 2005
                        • 2589
                        WRONG !! the first 3 03's I put the SOP on all threw random sc 991's. After I called Ricoh, I found out the java had to be 11.14 or higher and the machines came out of the box with 11.11............ This was early released units though................................
                        Mystic Crystal Revelations
                        • paulg
                          • Jun 2007
                          • 278
                          The firmware download service looks useful as long as the Machine is on @remote but as far as I am aware it will only update the package firmware which is most of the major Firmware files but not the Java?
                          If you use java I have learnt it is best to keep fairly up to date or on the new 03 MFP's switch it off via Sp mode 5 730 01 set to zero if not needed.
