MPC 3502
  • logrady2331
    • Feb 2011
    • 301
    MPC 3502
    Anyone know the printer model of the MP C3502? Gotta replace the fuser and need the EDP code for the printer version of this MFP. Never replaced one so I am assuming the printer model works with a little modification?
    • 37491
    Re: MPC 3502
    Why do you need to replace the fusing uniit?
    • Coptech
      worker drone
      • 460
      Re: MPC 3502
      3502 is D142 but I gotta ask the same question...why are you changing fuser. The heat sleeve assembly comes with fuse to reset fuser count and allow code reset.
      • logrady2331
        • Feb 2011
        • 301
        Re: MPC 3502
        The heat sleeve has a large cut in it and is making noise. The heat sleeve is around three hundred dollars and I have not priced the press roller. I know the printer version of the MP C 35/4500's, 4/5000's has a three hundred dollar assembly and was hoping the printer version of the MPC3502 (if there is one) would be less expensive. I was asking the product code/model number of the printer version of this model, not the product code of the MP C3502, I can get that from TSC on Ricoh. Maybe there isn't a printer version of this model and I need to just buy the heat sleeve?
        • Coptech
          worker drone
          • 460
          Re: MPC 3502
          Heat sleeve assembly, the pressure roller, (it comes with bearings and gear) and 2 different thermistors is pretty much a full rebuild on that fuser unless the exit plate has been damaged. I don't know if a printer model is available and convertible.
