Am i able to perform carbon copy printing with a Ricoh SP 4210n. Have two trays. if so which driver is required.
Carbon copy printing
Re: Carbon copy printing
i have a customer that wishes to print 2 of the same pages but on different coloured pages, thus they would then print from tray 1 (white paper) and tray 2 (lets say yellow paper) with the same information on each page. Hence the name carbon copy/ printing.Comment
To me, this would be something to setup in the software. For most word processing and publishing software, make a two page document with both pages the same. In the page setup, have page one print from tray one and page two print from tray 2.Comment
Install either the PCL 5 or PCL 6 drivers, in these you can use Paper Selection. If you use PCL 5 and select 2 copies, you can then use User Defined. With User Defined, set your white paper tray for page 1 and your yellow paper tray for page 2 (even though the document only has one page, the second copy is considered the second page).Comment
I don't think this will work, as far as I'm aware it will only send it down as a single job printing both pages from the same tray. I had a similar issue when a customer wanted to print two copies of a single page document on different trays then staple which by all accounts isn't possible either.
Would be good if you new different Ruben ?Comment
An off the wall thing, sorry if this is stupid.
Still, do you want to create carbonless forms? As in the ones where you sign the white sheet and the signature appears in the correct space on the yellow sheet? For that you have to buy the carbonless paper that already has the paper stacked properly. The machine should be able to handle making carbonless forms then (you might have to set the paper tray for light weight paper and you will have to glue the sheets together though).Comment
I have a couple of customers that simply use "coloured collated laser paper".
You can get it in 2 - 5 different colours. It's a pretty convenient solution, and only requires using 1 paper tray.
For Example: Colored Laser Paper - Collated, Multi-part Invoice PaperComment
I think sandmanmac's suggestion is exactly what you need.Comment
I've heard no mention if what application(s) you are printing from.
If it's MS Word, it would be fairly simple to write a macro within Word to get the desired results.
It should also be possible to write a VB script for other apps (like Acrobat or Reader.)
i would expect that there is a ton of very inexpensive (and expensive) software that would do this, as well.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
i would expect that there is a ton of very inexpensive (and expensive) software that would do this, as well.Comment
